87 Donor parting out
jjfugler
I still have quite a bit of the blue interior from this donor left to sale. Also still have the drive shafts, transfer case (dummy 2wd), most of the motor and some exterior trim. Custom steel tube front and rear bumpers need to go as well. Body is spoken for, Frame and axles still up for grabs though. Ya'll hit me up for these parts so I can get this out of here and get back to work on rebuilding my 90.
The donor is in Baton Rouge, however I work in the travel industry and have a crash pad in Grapevine, TX. So I can courier parts to anywhere that sounds like a fun day trip for me, or I can ship.
LeBronCo
North County San Diego
1987 and 1986
I need the the black plastic cover that is over the heater core in the engine compartment. I bought an 87 B2 a few months back. One night I turned on the heat only to have the cab fill up with smoke and sparks coming from under the dash. Pretty dang scary. Next day I was looking under the dash for clues; nothing obvious. I opened the hood and there it was. A partially melted plastic box with what looks like the heater core. I can get all the other stuff once I open this up but the box is a "no find 'em" item. Let me know.
Nelson aka LeBronCo
jjfugler
Nelson aka LeBronCo
I probably have it but not sure exactly what it is. You a pick of whats left of yours and location? I have pulled all the dash and things behind it, including all the black plastic air vents chambers.
LeBronCo
1987 and 1986
This part is in the engine bay just to the left of the motor. I'll take a photo of it and send it to you. OK?
Nelson
Yes.. he needs the non A/C heater box under the hood.
LeBronCo
1987 and 1986
Uncle G, I do have AC in my B2. I'll get a photo on here and we can figure it out. Thanks guys!
Nelson
I'm sorry... I got you confused with Ottoparts. He wants the non A/C box.
Carry on gentleman...
jjfugler
Nelson
What you got for me to go from? Pic? I tried to google this item and got nothing....
It's the under hood portion of the HVAC box bolted to the firewall.
jjfugler
which black thing under the hood mounted to the firewall...?
The big black box on the passenger side of the firewall... the entire thing.
15340
LeBronCo
1987 and 1986
JJ,
If you can pull that baby off the firewall how much would you want for it?
Nelson
jjfugler
Not much since I am not sure its useable. Let me pull that bad boy and get you some more pics. I had already started taking it off so wont take long. I will be home again next week to get it.
jbrady
Good morning, Would you have any of the tonneau cover bar attachments that mount on either side of the interior (two sets on my Eddie Bauer, forward and aft). These are the spring loaded fittings that hold the bar in place. Thanks
jjfugler
Yes I have them already pulled and ready to ship. You can contact me directly.
McWillies
Louisiana
2.9l
Nelson aka LeBronCo
The "heater core" looking thing would actually be your evaporator core (for the air conditioning). The heater core is up under the dashboard inside the cabin (look for the two heater hoses going into your firewall, heater core is on the other side).
McWillies
Louisiana
2.9l
Hey boss, you still have the front axle available? Also, what gear ratio is it? Worst case I can buy the front and rear end if the front isn't a 3.45 but I'd rather not have to pull the rear end out of mine just for that. Also need the radius arms, springs, and steering linkage if you got it (would come off the front as a whole pretty much).
Might be interested in the bumpers too if you'll post a picture.
Thanks.
Edit: Forgot to mention I'm just north of Baton Rouge, so I can pick it up or we can set up something.
jjfugler
Yep the axles are available. Bumpers sold about a week ago. Guy that got bumpers is wanting the whole frame so let me circle back and see if he still wants it. We separated the body from it before I flew back to work this week. Frame and/or axles will be ready to go this wknd.
Jhnybravo
Looking for rear seat arm rests (both sides)
Thanks,
New to the site, just joined. Purchased two B-2's a couple of weeks ago, let the fun begin!
